R remington New Member Sep 24, 2008 #1 What woul cause oil to get into the carberator on my 2000 fxst? Remington
Bud White Well-Known Member Retired Moderators Sep 24, 2008 #2 is it coming out the breather and into the carb or vlowing back from the intake .. could be a few things Overfilled with oil oil contamination breather system problems
G glider Veteran Member Sep 24, 2008 #3 remington said: What woul cause oil to get into the carberator on my 2000 fxst? Remington Click to expand... A few things could cause that. Over filled, bad umbrella valves in the heads, sustained high speed driving, oil pump alignment.
vnamvet Member Sep 25, 2008 #4 glider said: A few things could cause that. Over filled, bad umbrella valves in the heads, sustained high speed driving, oil pump alignment. Click to expand... Worn out umbrella valves, and sustained high speeds........yup, that's my guess....especially on a Sportster!! (I Know you have a softail!)
