Ok thx for the tip! Much appreciated! I do have a question though, why didn’t we see oil coming out of the air breather somewhere in those 200 mi. that it was ridden after me adding oil? The bike has been sitting for at least the last month before going to the car wash today and this happens
Honestly, I can't give a definite answer and can only make assumptions which are dangerous. How long had the bike been sitting when you checked and added the two quarts? It could be that the oil level was actually low. It could be that the girl friend didn't spin the motor up enough to build up enough crank case pressure to push the oil out; don't know.
To figure this out, more information is required. How long have you had the bike? How many miles on the bike? Is it stock/
When was the last time you checked the oil hot? Do you check the oil on the jiffy stand? When was the last oil/filter change? Who did the last oil/filter change? How cold is it where you live as that will have an impact on how long it takes to warm up and circulate the oil through the system?
If the bike sat for a month before the trip to the car wash, I can guarnatee that all the oil, full or not, was in the crank case. If you started the bike and took off before a five minute or so warm up, puking oil out the breathers/air filter is going to happen.
If the motor is not consumng oil and there are no oil leaks on the garage floor, there are only two places the oil can go. The most likely is the crank case but if the crank main bearng seal is leaking, oil can get pulled into the primary. If the motor was consuming that much oil, you would know it; smoke out the exhaust and oil grime all over the back of the bike; don't think that is the problem. You can check the primary by removing the derby cover and if oil has been escapting inot the primary, the excess will most likely run out.
What you need to do in order to identify the problem, you need to verify that the oil level in the motor is correct. You can do that by following the instructions in my previous reply. Get the motor hot and check the oil hot, on the jiffy stand and you can make adjustments from there. Once you have verified that the oil level is correct, never, ever, check the oil cold on a softtail. Get some pinch off pllers to prevent the gravity flow of oil from the tank to the crank case. Or, always warm up the bike befor e checking the oil and don't bother adding any oil until a quart low. That way you can monitor the oil level and if it is dropping youj will at least know that gravity is not the offender and you can look elsewhere. Comprende?
